Can you sync 2 Ipods to one PC ?
Discussion in 'Headphones, Earphones & Portable Music' started by Ekko Star, Nov 26, 2004.
Tags:
  1. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,177
    London
    +399
    About to get a second Ipod, just want to make sure that I can sync this with the same PC ?
    I won't have any problems doing this will I ? Would guess it should be pretty straightforward ?
  2. mark raeburn
    mark raeburn
    Nov 14, 2002
    413
    +19
    I've done this with no problems, the only issue is that your library will automatically be downloaded to both - unless you select a playlist to be downloaded only.
    This is an issue for me as the wife has a mini ipod, and i have a 20gb one, and I have too much music for it all to be downloaded onto her one.
  3. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,177
    London
    +399
    Thanks Mark, should have no problem then. Will be using two 40Gb ones.
