Can you still get a 5.1 decoder??
P
planetWayne
Does anyone know if you can still get a 'seperate' 5.1 digital decoder?
My hifi can handle 5.1 with separate audio connectors for each of the channels but unfortunately does not have any input for either optical or coax. So - I'm after a 'box' that will do it. Klipsch used to do the 'Promedia DD-5.1' which fits the bill spot on - but its a deceased product :(
Creative also seem to do little boxes for use with PC's - are they any good?
two main uses - DVD playback and xbox 360. so hopefully nothing thats 'cheap' if you get my meaning.
Any suggestions?
Wayne.
Knyght_byte
the Creative decoder will do the job fine, Creative are not exactly poor in respect to technology with music so i would imagine the stuff in the box is probably the equivelant of what you'd find in anything up to a £400 AV amp....
its just their speakers that sometimes let them down :D
P
planetWayne
Hiya!
So - Creative's DD-T100 should do the trick then?(Could only find the one!) I guess its up there from a quality point of view with decoding?
Just a case of getting the 1/4 Jack to phono sockets to connect to the amp...
Wayne.
