Badger0-0 said:Co-ax is a standard phono-type plug.
Optical is special, hence the inflated price.
Go co-ax, trust me, you are guaranteed to have that connection.
ThanksKnyght_byte said:oh and i dunno how much that QED Qunex subwoofer cable is, but i can say that there is no need to spend more than £20 for a 2m cable, or £35-40 for a 5m......i actually use a QED cable myself, but it wasnt a dedicated subwoofer cable, simply a QED digital coax cable and it works just fine....was worth £35 for 5m if i remember correctly, if i had the sub near the amp i could have used the 2m worth £20.......and thats on more expensive equipment....
Badger0-0 said:£25?????
Well, Ive given you my opinion and of course it's your choice
But I have to say
so to save £100 you have to buy £500 worth of cables to get 20% off which is £100 so you get £500 SRP of cables for £400? Have you got any idea what the margin in cables is? (trust me its alot more than 20%)Whappers said:Yeah, but hopefully I'll be getting 20% discount off the whole lot saving me hundreds.
hornydragon said:so to save £100 you have to buy £500 worth of cables to get 20% off which is £100 so you get £500 SRP of cables for £400? Have you got any idea what the margin in cables is? (trust me its alot more than 20%)
Badger0-0 said:Looks nice
But from the pics I can't tell what size it is
If it's a 42"
Either way, it makes no odds, IMO, a cheapy toslink will do the same job, regardless of what you're being told.
Digital is digital, there is no better way of sending it
yeah, true. I'll get a chance to demo the KEF iQ5's on thursday night when my friend will be working so I'll ask him for a price check of everything on the list. From what he has said to me in the past I am guessing that the prices are on average the same for the rest of the UK.hornydragon said:20% off the lot is pretty good (depends what the price is to start with tho)
Badger0-0 said:I'm sure it's a nice telly
Just don't get suckered into paying for an expensive toslink, is all I'm saying mate
Like I said, toslink is toslink, simple
Get a 3.5 mm to twin phono lead. Whether or not its gold plated and triple shielded or not would be up to you of course.Whappers said:Is there any way of getting audio from my laptop to the Denon?
I have been using a 3.5mm to 3.5mm audio Jack cable and cannot see any way of connecting it to the Denon. I have looked at several pictures of the receiver from the back trying to see any 3.5mm audio inputs but all I can see is outputs.
I plan to get a new PC at christmas time which will have a Creative Sound Blaster X-Fi Fatal1ty FPS Edition. So I will be able to connect an optical cable from the optical out on the 5 1/2 inch drive bay to the Denon.
Whappers
Whappers said:Thanks man, I can't believe I didn't think of that
So would I only be getting sound through the front two channels?, so in effect would it be 2.0 sound that I would be getting through a 3.5mm to phono? or would I be getting stereo sound but through all the channels?
Thanks.
Whappers
