Can you select the region code when recording
Discussion in 'Blu-ray & DVD Players & Recorders' started by davepuma, Aug 13, 2004.
  1. davepuma
    davepuma
    Jun 24, 2004
    17,507
    +3,503
    I'm currently out in Singapore at the moment and am considering buying a DVD recorder. All players seem to be multi-region out here, however as Singapore is region 3 does that mean that any DVD recordings I make are region 3 or are they region free. Sorry if it's a daft question!!! :blush:
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,855
    Warwick
    +2,773
    DVD Recorders do not assign region coding to recordings made on them - so any recordings you make in Singapore will indeed by Region Free.
    If you planning to buy a DVD recorder to bring back to the UK do note their may be 'issues' such as different tuners etc.
  3. davepuma
    davepuma
    Jun 24, 2004
    17,507
    +3,503
    ...didn't think they would record in a particular region but just thought I'd better check. As for the tuner issue I will look into it, however, I would be using SKY for my recordings anyway.
    Dave
