Can you record off Sony KD28DL11 digital tuner?
MikeD
Hi there I am seriously considering getting a Sony KD28DL11 and I want to connect my panny Sky digi box and thomson DVD/hard drive recorder to it.
Is it possible for me to watch SKY on the TV whilst at the same time recording from the TV's digital tuner?
Regards, MikeD
GreenBars
Assuming it works in the same way as my KD28DX50, it shouldn't be a problem. With mine, you set the AV2 to output either the signal from the TV's Freeview tuner, the signal from the AV1 input or the signal from the AV3 input. You can then watch whatever you want: Freeview, AV1, AV2 or AV3.
I have it set up so that the Freeview signal is output from AV2 to my VCR, while I watch NTL on AV1. The same would work for you with Sky.
Eso
I have this TV, and as said you can record freeview.
For me I have my VCR in AV2, change to that channel, select Line1 on the video, which picks up the freeview, hit record and away it goes!
(Sorry for the really poor description of how it's done, but it can be you just need to wire it in right :smashin: )
MikeD
Thanks for the replies guys.
Eso can you watch a different channel on the analogue tuner at the same time as recording from the digital tuner though, I know some sony tv's will allow this.
Greenbars KD28DX50 and I think other Sony's with digital and 3 SCART sockets are probably able to do this although I cant be certain, the KD28DL11 only has two SCARTS.
Regards, MikeD
GreenBars
The KD28DX50 only has two scarts like the KD28DL11. The AV3 I referred to in my original reply is the front composite/s-video input.
MikeD
Hi Green bars thanks for the info, all I need now is for someone with a KD28DL11 to confirm whether I can record from it's freeview digital tuner whilst watching SKY on satellite at the same time?
Eso
I assume you can watch the analogue tuner whilst recording digital, though I have never actually tried it.
I would think it is possible though. I'll try and have a go later and report back.
I don't think you would have a problem with watching SKY or anything else as once you set the VCR to line 1 (or whatever input the digitl is fed to) I assume you can do whatever you want with the set other than change channel.
Hisense U7H TV and T+A Solitaire T headphone reviews, AV/HiFi news plus, what is screen uniformity?
