Can You Mix subs???
Discussion in 'Subwoofers' started by damtom1, Jun 22, 2002.
  1. damtom1
    damtom1
    Can you mix subs?Will you get a balanced sound from ...A Paradigm PDR8+PDR 10???or... a REL strata 1+Rel Strata 11??etc...Maybe keep the manufacturars,but change the models??
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Providing they are setup properly then you should be able to match any pair of subs.
    Seting up a mis matched pair will be harder than a matched pair. but using a Strata 1 and Strata 3 would be fine.
