can you manually region change these two players
Discussion in 'Blu-ray & DVD Players & Recorders' started by pauljameshooper, Jun 14, 2001.
  1. pauljameshooper
    pauljameshooper
    the two im on about is the Tosh 3109 and the hitachi p250...its just ive been reading up on this rce b******s and i dont think its worth getting a multi region player...but its worth buying one that you can manually change ( or Hack) to become the region you want i.e. R2 to R1
    If anyone can help id really apprieciate it..
  2. Fartpants
    Fartpants
    Check with your supplier, I would expect you woud have to get both these players chipped, so the supplier will tell you if they work with RCE and if you can switch between auto and manual changes.
