Can you make XBMC upscale to HD?
truebluenose
Just recently got a 26" Panny LXD60 and have currently got it connected to Xbox via an RGB xbox scart lead. I've heard you can get component cables to get it to upscale but is it really that easy?
PS. Xbox is softmodded with Softmod.Installer.Deluxe.v2.0.Xbox-Hq and XBMC is set as my dash.
Cheers!
Drunkeh
You need to convert your box to ntsc, then in the normal xbox settings theres component out setting If i remember correctly.
tredman
Cheers!
See one of my posts on the last page of Xbox Component Cable thread
truebluenose
Cheers for the help guys. Now have my monster component cable connected and everything enabled. Successfully streaming video from my pc and upscaling to 480p but my question is can I get it to upscale further to 720p?
Cheers.
scumball
If you have enabled 720p & 1080i in the MS dashboard then you should be able to change the XBMC GUI to 720p or 1080i. Then anything you play through XBMC will be upscaled to the GUI resolution (if this setting is checked).
truebluenose
Cheers worked a treat. Now my set up is near perfect. Only thing that is still a bit annoying is I have to adjust the aspect ratio using yellow button each time I play a new video. "Normal" and "Stretch 16:9" seem to get it to fill the screen. Any ideas how this can be done automatically?
Cheers.
