Can you loop through a DVD recorder to plasma?
Discussion in 'Plasma TVs Forum' started by toby_smith, Jan 28, 2005.
  1. toby_smith
    toby_smith
    Oct 13, 2004
    63
    I've been looking at how I can archive off my Sky+ movies to DVD, but am aware of some restrictions like losing the 5:1 sound.
    Given that my 2805 outputs in 5:1. and component to my plasma, I wondered if it is possible to put a DVD recorder between the 2805 and my plasma, and when I want to archive off a movie, just record onto the DVD.
    I guess this would require both component input and output on the DVD recorder to allow the loop through, as well as an optical input.
    Is this possible, and does such a DVD recorder exist?
  2. docb
    docb
    Nov 22, 2004
    253
    the sky box wont output component, you will have to use scart (RGB?) to take the signal to the DVD.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    YES i assume you are going S-video in to 2805 so use RGB scart into DVDR (panny DVDR will then output via component back into 2805 for watching (if you have a spare input or can use S-video in and out of DVDR I would get an E65 now before the new awful looking things come out...
  4. toby_smith
    toby_smith
    Oct 13, 2004
    63
    OK, I should have mentioned that I go from Sky+ through a JS RGB-YUV convertor to the 2805.
    Also, I've already got a 2910, so I can use this for playback, and/or use the recorder - the point being is that I can get away without having a top quality player since I've already got one.
    What I'm wanting to achieve is to get the movies from Sky+ archived off, but maintaining the 5:1 sound.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    to retain 5.1.......Hmmm i think D-VHS is the only current option. Rascazk will know
  6. toby_smith
    toby_smith
    Oct 13, 2004
    63
    according to his guide, there are no DVD recorders that can record 5:1 sound presently. :thumbsdow
    I thought in hind-sight that perhaps I'd got it wrong with my Denon 2805/2910 combination given my preference to now archive from Sky+, but for the time being at least, there is still no ability to archive 5:1 movies.
    Perhaps the answer is to go for a larger hard disk in the Sky+ box. Now I know there are loads of threads to be reading about this...... :zonked:
