Can you link two Netgear DG834G's?
Discussion in 'Networking & NAS' started by Discombobulate, Jan 12, 2008.
  1. Discombobulate
    Discombobulate
    May 6, 2003
    7,516
    +618
    I have a v2 of this wireless router and Tiscali have kindly given me another one (v4 model).
    I was hoping to connect them both to extend the wireless range round the house but am struggling with how to do this.
    The set up for the v4 model seems to have options to work as a bridge/repeater but I can't fathom out what I'm meant to do.
    The v2 model doesn't.
    I've tried connecting both to a phone line separately in the hope they could both access the internet separately and then I'd log on to the right one dependant on where I was in the house but this didn't work.
    I'm with Tiscali and it looks as if they only allow one router to log on at a time. I can get either one on the internet but not both at the same time.
    Any help to get them connected in a bridge/repeater fashion or individually at the same time would be appreciated.
  2. sinizterguy
    sinizterguy
    May 19, 2005
    1,007
    48
    +47
    Set one up connected to the phone line and all that.
    The 2nd one acts as a bridge/repeater. This is not connected to the phone line, but it is logged into the wireless network of the first router and retransmitting the signal.
  3. Member 79251
    Member 79251
    Jul 2, 2005
    13,421
    +2,187
    I think its v2 to v4 and away you go.
    Box 1 would have ip -> 192.168.0.1
    Box 2 would point to box 1 -> 192.168.0.1
    So get 1 box working first and then take it from that. ;)
  4. t72bogie
    t72bogie
    Jul 17, 2007
    3,102
    UK
    +532
    you would need both models to support WDS repeater mode...but im afraid the v2 dosent so its not possible.
    only way to do it would be to buy a WG602 access point and use that as a repeater for the Dg834Gv4
  5. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
    Be aware that using an AP or router in repeater mode will result in data rates being halved; this won't matter if it enables wireless access from a previously out-of-range location (a bit slower beats not available).
    Chris Muriel, Manchester
  6. Discombobulate
    Discombobulate
    May 6, 2003
    7,516
    +618
    I have box 1 (the v2) working. Can't see the option on box 2 (v4) to point to box 1.
    Do you know which option I should use.
