Can you increase the volume of the rear speakers.
Discussion in 'Desktop & Laptop Computers Forum' started by paulr, Jun 30, 2002.
  1. paulr
    paulr
    Jun 5, 2002
    1,159
    North Lincs
    +65
    Basically i have just got a new h/c setup and would like to increase the volume of the rear speakers.
    Denon 1602 amp,Energy take 5 speakers.
    The room i have is very long and the rears are a long way from the tv+where i sit...........i'd like them a bit louder,.....is this possible
    Thanks ........Paul
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,632
    UK.
    +3,132
    There should be a way of increasing/decreasing all speakers individualy in the menu or via buttons on the amp.
    My 3802 can do this, and so can my very old Pro Logic amp, so I'm sure the 1602 can as well. Have a good look through the manual.
    HTH
    Gary.
  3. paulr
    paulr
    Jun 5, 2002
    1,159
    North Lincs
    +65
    Cheers Gary.......will do.
  4. Dominic
    Dominic
    Mar 2, 2001
    289
    Essex
    +6
    can you move the rear speakers nearer to the listen position.?
