Can you increase the time before voicemail divert on Nokia 6230i?
Scapegoat
Recently got a Nokia 6230i. At present it only rings for 5 rings before it diverts to the voicemail service (on Vodafone).
Is there a way to change the settings to increase the time it takes before it diverts?
RBZ5416
This is a network setting & nothing to do with the handset. PAYG is fixed & can't be altered. Contract phones can be adjusted as follows:
You can extend the ringing time before your calls go to Voicemail in multiples of 5 seconds up to a maximum of 30 seconds.
You simply need to dial:
**61*(mailbox no in international format) *10* (no. of seconds)# send
To get your mailbox number simply dial
*#104# send
International format includes +44
Scapegoat
*#104# send
Thanks for the information, but I think I am doing something wrong.
When I request the mailbox number I get 12 digit number (first 2 are 44) then a space and then 7 letters with a dash after the first two.
I have tried the above with the 44, without 44 - but it says unknown command after it has submitted request.
Any ideas what I am doing wrong?
EDIT
Tried it again with a + before the 44 (as you say in your message!) and it works.
Thanks you very much for your help.
Scapegoat
*#104# send
I have tried the above with the 44, without 44 and with +44 - but it says unknown command after it has submitted request.
3T3L1
I had this problem and ended up ringing Orange customer services to get it sorted - they were very helpful and told me what to do accurately. I can't remember how to do it now unfortunately, but that's what I'd suggest!
uczmeg
Life in an old thread, but in case someone else happens to google it as I did:
Just been trying to increase this on another phone and can see a flaw in the instructions...
The *10 should be *11, so it should be:
**61*(mailbox no in international format) *11* (no. of seconds)# send
Still didn't quite work for me. Putting in the international code for the voicemail failed. However just putting in 121 (on vodafone) worked perfectly!
So for a 30 second delay on vodafone you would enter this:
**61*121*10*30#
A full list of codes can be found here:
http://www.mobileshop.org/usertech/gsmcodes.htm
