I have a PS3 which I run through a Sony HT-SF1300 system. It has been running fine since I got the system in October last year but last night when I switched it on it came up saying it detected a HDMI lead connected and did I want to use it - I have only had an HDMI in there since I got the sound system and had not touched it! - i said yes and since then the sound keeps dropping out if that's the right term - I get, say, 3 seconds of sound then 1 second missing over and over and over and over again - it drives you mad and there's no way you can use it.
I thought maybe the lead had developed a fault so I swapped that over - no different.
I put it into a different input on the sound system - no difference and sky etc. work fine in all inputs
I put the HDMI direct from the PS3 to the TV and it works fine - except I want it through the sound system!!
Any ideas?
thanks
Any ideas?
thanks
