Can you get XLR-to-RCA adaptors?
Discussion in 'AV Receivers & Amplifiers' started by daninthemix, Feb 20, 2003.
  1. daninthemix
    daninthemix
    ...and if so where? I assume this is accomplished by only connecting the positive line through (not the negative or ground), but is there a good way of doing this, without compromising the quality of the connection?
  2. sounddog
    sounddog
    Dec 11, 2002
    3,438
    107
    Leicestershire, UK
    +477
    Which end of the connection is the XLR (balanced) connection.
    If you want to keep optimum connection throughout ... try getting either balanced line recievers (pre-amp has balanced line outs but power amp only has un-balanced ins) or balanced line drivers (other way round).
    As for where to get these, or passive connector converters ... try Canford - they are a supplier to the pro sound industry but will supply to individuals with credit card (well they used to anyway)
    Victoria
  3. daninthemix
    daninthemix
    Thanks for this link! I might not need one, but useful to know anyways!
  4. PaulP
    PaulP
    Hi Dan,
    No.
    XLR balanced is + - and ground, RCA unbalanced is + and ground.
    If you are talking about analogue connections (eg not SPDIF or AESEBU):
    To convert from Bal to/from unBal, you need a balancing transformer, or as sounddog has said, the active equivalent.
    Or you can hard wire (or get a hard wired adaptor),
    XLR + to RCA +
    XLR - and ground to RCA ground
    and this will work in many cases, but you lose the advantages of the balanced connection (eg hum rejection and so on) - this may not be a big deal if the signal level is high (eg line level) and the cable run is short, YMMV.
    NB some balanced devices might complain about having their - line tied to ground.
    Another supplier is StudioSpares in London,
    http://www.studiospares.com/viewproducts.asp?cid=3437&ctitle=ADAPTORS - XLR&p=1&gid=5
    their (hard wired) adaptors are £6.59 GBP.
    If you are talking about SPDIF / AESEBU conversion, (75 ohm unbal to 110 ohm bal) then an adaptor with built-in pulse transformer is what you need. Canare make these, as do Neutrik. Again Canford or Studiospares can supply these.
    best regards,
    Paul.
