Can you get away with a centre speaker?
Discussion in 'Home Cinema Speakers' started by Scotty Boy, Oct 27, 2004.
  1. Scotty Boy
    Scotty Boy
    Nov 11, 2003
    1,106
    38
    +6
    Just set up my new screen on my oppli bench, and it looks brilliant. Unfortunately, if I want my centre speaker up and running, it's going to have to go on the wall. And it's a bit of a beast you see.
    Have a looksy.
    [​IMG]
    What i'm asking, is can I really get away with one? or am i going to miss out alot with DVDs and playing on the xbox. It just seems a shame to put a speaker above it, as it looks great as it is.
    EDIT: The centre speaker isn't as big as it looks in the pic. Heh, here's probably a better pic.
    [​IMG]
  2. Scotty Boy
    Scotty Boy
    Nov 11, 2003
    1,106
    38
    +6
    The title is meant to be 'without' not 'with'.
  3. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    Is there not enough space 'behind' the screen?
  4. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    most speech comes out the centre speaker
    can you really do without the speech?
  5. John Watts
    John Watts
    Jan 27, 2001
    3,961
    71
    Leeds
    +80
    IMHO, No!
    Like pjclark1 says you will lose essential dialogue.
    You'll still have a good sound but with alot missing.
    Try it with and without and then make up your mind.
  6. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,373
    71
    Liverpool: European Capital of Football 2005/2006
    +76
    scotty see my edited post in Get Yor plasma's out
  7. Scotty Boy
    Scotty Boy
    Nov 11, 2003
    1,106
    38
    +6
    Ah, i didn't realise the majority of dialogue came out of the centre. I'm definately getting it up on that wall tonight then. It could fit on the oppli behind the screen, but that would seem a bit odd.
    I'll push the oppli back a little and the screen and have the Speaker behind and above it :)
    Cheers lads.
  8. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    9,043
    Babel Sensurround
    +207
    Why don't you precariously balance the plasma on the centre speaker :eek: :devil:
    Seriously though your room looks :thumbsup:
    Adrenochrome.
  9. danburbridge
    danburbridge
    i would disagree - if the imaging is good enough from you front two speakers then there is no real need for a centre speaker IF the screen is exactly in the middle of the two speakers. the other issue is whether your amp supports phantom centre speakers
  10. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    k3ys3r
    you misunderstand, dolby 5:1 and DTS do not route speech to the front side speakers in many movies. The speech only comes out the centre speaker. The other speakers only play music and spot effects. Course if you listen to your movies in dolby 2.0 there is no problem, but it kinda defeats the purpose of buying 5:1/DTS amps.
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    you can use a "phantom" centre Amp will processes dialogue into FR & FL how big is centre will it not fit infront of screen.....
  12. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,373
    71
    +76
    i suggest propping the display about 8" or so higher on some sort of stand / mount then having the center in front of it. this wont interfer with the screen then
  13. danburbridge
    danburbridge
    dont worry pj -i do understand thats why i mentioned the need for a phantom setting on the amp - so that it combines the centre channel into the l+r ones
  14. common
    common
    Mar 5, 2001
    1,397
    41
    Oxford UK
    +8
    I don't miss mine, just running 2.0 and quite happy
  15. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,373
    71
    +76
    scotty this what i was on about before and would suit you ideally
    [​IMG]
    [​IMG]
  16. KHCC
    KHCC
    Aug 10, 2004
    256
    Kent
    +10
    Mornin'
    You could try wall mounting the plasma at the desired height so that you can put the center speaker on top of the AV unit.
    Regards
  17. Keiron
    Keiron
    Feb 22, 2001
    3,312
    Stockport
    +108
    I still have mixed feelngs on the benefit or otherwise of a centre (admittedly I seem to be in a minority). It's been debated a few times here, most recently in a thread entitled "Centre Speakers vs Full range stereo pair".
    I find it odd that in the days of mere stereo, we were all quite satisfied that two front speakers could satisfactorily produce the illusion of sound coming from slap bang in the centre.
  18. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,373
    71
    +76
    yes but for 5.1 ch like DD and DTS you try watching a Film (which i assume is what his system is used for) without the Center Channel. its a big miss imo when its not there. you can do all the audio processing thru the amp but its just easier and better to have the center channel. id try make room for it some where
