Can you get a 6 foot tab tensioned screen??
akarit1
Established Member
Well the heading pretty much asks the question. Is a 6 foot wide tab tensioned screen available from anywhere as I have only seen 8 feet wide and above on these forums. I can go to 6.5 feet at a push but no larger as my room is quite small. I want it to be electrical with infra red remote/trigger.
Any help would be great, thanks.;)
mateusz1
This are the smallest one I know off.
DRH
Beamax | M-Tensioned projection screen 174x102 16:9
Beamax shows out of stock but I'm sure they would make you one quick.
Anyway bear in mind that cases on those screens are much longer than the fabric size , so always check before you buy one.
Good luck in your search :thumbsup:
Peter
Spielberg, Shyamalan, Aronofsky, Chazelle, Eddie Murphy and Mel Gibson - all the latest movies
