Can you get 8' x 5' MDF?
Discussion in 'Home Cinema Building DIY' started by rooster, Dec 11, 2002.
  1. rooster
    rooster
    Mar 18, 2002
    224
    Edinburgh
    Might go down the MDF DIY screen route but really wanting a 78" x 44" (16:9) screen
    So with 4' MDF this would only leave 2" for masking border. Would this look a bit odd? Or maybe I could make frame andhave it overhanging screen a little.
  2. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Hi Rooster,
    I know that trade suppliers (not sure about B&Q) supply sheet materials including MDF in 8'x6' - but if it was me I'd use the 2" at the top and the bottom and let the frame overhang a little - the frame wouldn't be much more than 4" wide altogether, would it ?
    Sean G.
  3. rooster
    rooster
    Mar 18, 2002
    224
    Edinburgh
    No 4" is what im looking for. Just think 2" would be too narrow and look a bit odd
