can you get 6.1 or 7.1 audio fromt eh HD-A1 ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by jamieuk23, May 3, 2007.
  1. jamieuk23
    jamieuk23
    Oct 25, 2004
    2,173
    +26
    Hi I notice in the HD-A1 menu it only seems to support 5.1 setup which I currently have, but in the future when I move house I would like to use 6.1 or even 7.1 setup.
    can you see any problems getting 6.1 or 7.1 output using this DVD player as I am not sure how a Amp would work when its being sent 5.1
    Little confused about this and hopefully you understand what I mean
    :confused:
  2. Twan1
    Twan1
    Dec 19, 2004
    1,195
    38
    Essex
    +22
    Jamie there is no way to get more that 5.1 if using analogue the conventional way.
    I have a 7.1 setup and really wanted to use my extra rears so i had a custom made lead which now send the same signal to both sets of rears (side and rears) this is not true 7.1 but it makes a big difference to me!
    So i plug in the 7.1 connectors to my amp which feed down to 5.1 on the back of the player.
    I dont have nor intend to buy a new HDMI amp so i dont know if that supports it yet.
    One other thing to mention is that none of the disc that i'm aware of are actually programmed with anything more than 5.1 at this stage anyway so it would only be matrixed sound.
    There could be some amps out there that take a 5.1 signal and automatically matrix it but mine didnt (Naim AV2) so i prefer to go down my option rather than buying a new amp)
  3. jamieuk23
    jamieuk23
    Oct 25, 2004
    2,173
    +26
    thanks for your input mate !!
    How are you taking to this new HDMI 1.3 version ?? Will you be upgrading to it when it comes to the new AMPS ?
    It seems as soon as you get your perfect setup there is something new around the corner.
    Notice you have the pannaonic AE1000 same as me, do you no if the HDMI ports on it are 1.3 ?
    Sorry for all the ?`s !
    :smashin:
  4. jamieuk23
    jamieuk23
    Oct 25, 2004
    2,173
    +26
    All so were did you get that cable made mate ??
    Good thinking ! :thumbsup:
  5. Grumble
    Grumble
    Mar 16, 2005
    223
    20
    St. Andrews, Fife
    +85
  6. Pecker
    Pecker
    Dec 26, 2004
    22,494
    Huddersfield, People's Republic of Yorkshire
    +4,612
    I don't have the new HD DVD DVE disc, but I have the SD one.
    My HD-E1 definitely outputs dts-es discrete (1.5mbps) over optical, even though the Tosh spec says it can't.
    Steve W
