can you convert this to a normal 3 pin plug?
Discussion in 'Cables & Switches' started by thecount, Apr 26, 2005.
  1. thecount
    thecount
    Mar 15, 2004
    173
    I have a kenwood midi hifi turntable and the power plug on it is like this (see attached), I'd like to be able to convert it to a 3 pin plug without just simply cutting it off and putting a 3 pin plug on it. are there any options?
  2. BeStu
    BeStu
    Feb 18, 2005
    164
    16
    France
    No probs!! All you have here is a 5 amp twin with no earth. I.E. just connect the existing cables to neutral and live (it doesn't matter in which order) IMPORTANT!!!!!!! you are sure that this equipment IS 220-240 volts????? If its US in origin it may be 110 volts in whihch case DO NOT COONECT to the UK mains supply!!!!!!!!! Assuming it is 240v use a 3 amp fuse. If in ANY doubt consult a qualified electrician.
  3. thecount
    thecount
    Mar 15, 2004
    173
    Ok, but as I explained, I don't want to chop off the plug, is there not a converter to UK 3 pin?
  4. BeStu
    BeStu
    Feb 18, 2005
    164
    16
    France
    Ok try this... get your hands on a kettle lead offer your TT plug up to it, you should see that both of the terminal pins line up with the sockets on the kettle lead. If so ou are in business!! If not I'm afraid its out with the snips. Anyway assuming the pins and sockets do align you need to carefuly remove the plastic locating lug on your TT lead (this will have no adverse effect on the plug... you just need to be a little more careful when plugging it into the outlet (pesumably on your other Kenwood gear) I removed some lugs I had on cables many years ago wthout too much difficulty, if I remember right I sed a stanley knife and a pair of pliers, don,t cut yourself I always do....
  5. thecount
    thecount
    Mar 15, 2004
    173
    thanks, will try it!
