can you buy such a thing????
Status
Not open for further replies.
dogtown
I've figured out what i need but dont recall seeing one before.
Im basically looking for a box with 16 binding posts for banana plugs to fit and wires coming from each post out the back.
The top 8 wires all plug into the music amp, then the speakers plug into the top holes on the box.
The bottom 8 wires will all be plugged into my av reciver, then i can remove the plugs out of the top and into the bottom for when watching films tv etc.
This way i can switch all my speakers between 2 amps without having to get behind the amps themselfs.
Can such a box be bought??
Wouldnt be too hard to make.....
dante01
You keep starting threads asking what is basically the same question, a question that is already answered!:
http://www.avforums.com/forums/av-a...99-possible-use-2-amps-but-same-speakers.html
http://www.avforums.com/forums/av-a...67488-bit-complicated-one-please-bear-me.html
http://www.avforums.com/forums/av-a...50-new-amp-has-landed-but-there-must-way.html
Why not use one of your existing threads rather than start a new topic?
dogtown
totaly different mate, this thread (if you read it) is about a 4 pair of speakers box that can tail off to each amp, 2 boxes, 8 binding posts in each, each box is connected to each amp which makes changing the speakers over a pizza ****.
Just ordered the bits to make.:smashin:
dante01
Then you are posting in the wrong forum. You require a speaker switch/Amp router, not an AV amp.
KUBBY
Should you have any issues with this Device,would you Post in the Interconnects and switches Forum HERE,please.
I'll close this.
K.
Status
Similar threads
Podcast: New TVs, Samsung Q800T Soundbar review, IFA latest, Movie and AV News, B+W Brad Pitt
