Can you build a plasma display into the wall?
Discussion in 'Plasma TVs' started by ziglar, Dec 18, 2003.
  1. ziglar
    ziglar
    Dec 1, 2002
    329
    Berkshire
    +16
    Are there any plasma display models that are designed to be built into a wall rather than mounted on it?
    Presumably, if you tried this with a normal plasma display you would need to provide for some means of cooling/venting?
    Stuart Smith
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    try tile vision and see what you can find!
    Can be done but screen still needs ventilation!
  3. Andrew_B
    Andrew_B
    Dec 3, 2002
    198
    Bath
    I downloaded a technical manual from Pioneer for the 433/503MXE and it had loads of detailed instructions on mounting the plasma, including embedding into a wall.
    Take a gander over at Pioneer and see what you can find..
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,049
    The Borders
    +2,522
    Hello Ziglar
    No 'In wall' purpose built units I know off - a bit too small a market I guess.
    With care and lots of pre design you can flush mount pretty much any display you fancy - getting cool air to the rear of the display is one tricky bit; how to mount it, get it cabled, gain access for service and have a neat border around the aperture are just as much fun at the planning stage.
    Best regards
    Joe
