Can Upscaling DVD players do 720p/1080i via component?
Discussion in 'Blu-ray & DVD Players & Recorders' started by 9761, Dec 26, 2006.
  1. 9761
    9761
    May 16, 2005
    536
    I just need to know that do upscalling dvd players upscale with component?
  2. Greg Mandel
    Greg Mandel
    Jun 10, 2006
    312
    +30
    Generally no, though there are one or two about that do. Most only upscale via HDMI.
    Check your display, as they are usually capable of upscaling any signal that comes into them, and could very well do it better than a cheap DVD player.
  3. 9761
    9761
    May 16, 2005
    536
    Well tv is a panny 42px60 i think, so would that upscale?
    thanks
  4. cyrus-t
    cyrus-t
    Feb 28, 2004
    181
    +16
    hi there. I've got a samsung dvdhd850, which I believe, out-of-the-box, wasn't multiregion, nor could it do upscaling via component.
    After running the handset hack (which I was really doing for multi region), it also upscales via component as well, which is sweet. Ironically it's in the 'hdmi' menu setting or something, but whatever, it certainly does it.
    Even the girlfriend notices a difference :thumbsup:
