can u make a monitor wireless ?
discostewart
hi im wondering if a monitor can be made wireless in the same way a keyboard and mouse can. im not talking the power supply here just the link to the computer so i can put the CPU box in a cupboard.
Monty Burns
You sure can!
But there are problems/limitations. Why not check out THIS example. If it seems OK to you then you may want to just google for similar.
Good luck
discostewart
thanks so the limitations seem to be no DVI and you cant do movies and probably not games?
hmmm too much of a trade off another dream btes the dust lol
