Can u help? Power Indicator Is Flashing Rapidly On my 3801
Discussion in 'AV Receivers & Amplifiers' started by akan7, Mar 23, 2003.
  1. akan7
    akan7
    Dec 11, 2002
    327
    28
    England
    +63
    :( On my Denon avr-3801 when i turn the volume up the amp go to standby and the Power Indicator Is Flashing Rapidly
    just start doin this.
  2. magking
    magking
    Jan 6, 2001
    380
    Norway
    It means that you are asking for more than it can give.;)
    Well it can be other things.
    To hot, make shure it has enough space.
    Short sircut. Make shure none of the speaker cables touch each other in any place.
    Can also be something internal, but you don't want to go in there.:nono:
    It can probably be other things, but these are the ones that i can think of now.
    Good luck and let's hope it's not internal.
