Anyone else unable to turn it off and put it standby mode by using the on/off button under the disk slot? It turns on but i have to put it on standby by using the sixaxis.
I think i'll use the controller, don't want to hold it down too long as it resets the HD settings doesn't it?
Are you sure ? I would be surprised if it did.
Yeah if you hold it for around 5 seconds it reverts to default resolution, this might only be when you turn it on though.
http://216.239.59.104/search?q=cach...ml+ps3+reset+default&hl=en&gl=uk&ct=clnk&cd=8 (half way down the page).
