Can Toshiba 36ZD26 accept PAL progressive ?
Discussion in 'Televisions' started by nja, Jan 6, 2003.
  1. nja
    nja
    Mar 1, 2002
    58
    Chatham, Kent
    +3
    I assumed that the xxZD26P TV could accept PAL progressive. Can any owners confirm from personal experience if this is the case as I am about to buy a PAL progressive DVD player and will be a bit gutted to say the least if my PAL DVD's don't work in progressive mode. :confused:
  2. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,109
    83
    Over the Hill & Far Away
    +118
    From the other posts I have read on this when I considered buying the Tosh... no the Tosh does not support PAL progressive.. you will just get a green screen.
    I believe the Panasonice PL40H (I Think) is the only CRT which will do PAL progressive as well as NTSC.
    Matt
  3. sr78
    sr78
    Sep 26, 2002
    281
    New Panasonic 32PS20D is much cheaper, around 800 pounds, and has the same features as teh PH40. It's only available in Germany and France though...
  4. nja
    nja
    Mar 1, 2002
    58
    Chatham, Kent
    +3
    Thanks for the replies so far - still have not seen any thing from anyone that has actually tried a PAL PS input to this TV - perhaps someone could point me at the relevant post if there is one as I can't find it.
    If it is sadly true that PAL PS won't work, does anyone know if the TV can be upgraded ?
