Can this box recieve channels via a tv arial
Discussion in 'Satellite TV, Sky TV & FreeSat' started by waynewickenden, Jan 27, 2005.
  1. waynewickenden
    waynewickenden
    Hers the spec:
    Works with WideScreen and Digital audio
    "No Fuss' Menus are easy to use
    Receives all Free to Air Digital Satellite Channels
    No subscription required - ever!
    Integrates with existing equipment; VCR,DIGIBOX,CABLE,SAT,TV etc
    Flexible installation into both Domestic and MATV Systems
    Tuner Input/Output for Digital aerial loopthrough
    Modulator Input/Output for Coaxial loopthrough
    Twin Scart connection to suit Domestic Television applications.
    High speed channel change
    Dolby Digital 5.1 Optical output
    12 months RTB Warranty
    Does anyone know if this will recieve the channels through my arial,
    For information about this product you can visit http://www.satalogue.com/section16/index.htm
  2. waynewickenden
    waynewickenden
    I desperately need to help on this as i have purchased one of these boxed via the website listed above this evening, and the helpline to cancel the order if it aint ablt to get through the tv areal closes at 7pm tonight
  3. Fred Smith
    Fred Smith
    Apr 23, 2004
    1,901
    Reading
    +291
    Wayne,
    You have PM.
