can this be done mce 2005
Discussion in 'Microsoft Windows' started by makey, Mar 13, 2006.
  1. makey
    makey
    Mar 11, 2004
    202
    28
    +35
    right lads
    just got an xbox 360
    and i want to stream video files (dvd,divx,mpeg,hdtv files) from pc to 360
    i have at the moment xp pro sp 2
    and have been told i need mce 2005 for it to work
    the question i need to know is
    1. can i run mce over my xp pro (as i have a lot of software i dont want to loss)
    2. do i need to have a tv tuner card(dont have one at present)
    3. are these spec ok for streaming hd film to tv via 360 over a wired network
    Athlon 64 3200+
    asus motherboard
    1024mb 2700 DDR
    200gb sata hd x 2
    80gb hd (external)
    nec 3450 dvdrw
    NIVIDIA Geforce 6600gt(128mb)
    Windows xp-pro (sp2)
    thanks guys
  2. movaado
    movaado
    Dec 16, 2005
    514
    46
    Sittingbourne, Kent
    +220
    MCE is a different version of XP, its effectively XP pro + media center minus the ability to logon to a domain. You would have to purchase MCE and install that.
    The xbox360 extender software doesn't support divx or xvid
    Don't think you need a tv card for streaming video (you would for playing back recorded tv, which you can't record without a card so its not really an issue).
    The PC is more than powerful enough.
