Can the volume increasor solution be used for the SONY NW-HD5H?
Discussion in 'Headphones, Earphones & Portable Music' started by captainnorth, Aug 10, 2005.
  1. captainnorth
    captainnorth
    Jun 5, 2005
    Really wanna get the 30gb NW HD5H.
    Does anyone know if the volume increasor cheat works?
    also has anyone had any probs with buttons cracking?
    Thankful for any assitance I am.
    Captain North :)
  2. johann1979
    johann1979
    Feb 18, 2005
    857
    19
    London
    You can remove the volume cap on the HD5 by using the same code and entering the service menu. Look here. No reports of HD5HS 30GB with fracturing buttons yet - that I know of ;)
  3. realslimcookie
    realslimcookie
    Oct 6, 2004
    243
    Hull, UK
    +3
    I can confirm it works for the NW-HD5H, just follow the link in the post above and if you don't get it right the first tim, try ans try again because once you address the volume issue you will realsie just how low the volume cap is set!
    Realslimcookie
