Can The Viera TH-50V30P be repaired
Discussion in 'Plasma TVs Forum' started by Kamin99, Jun 2, 2005.
  1. Kamin99
    Kamin99
    Sep 15, 2004
    346
    +10
    My Panasonic Viera TH-50V30P lasted over a week before a thin dark line splits the screen, it was picked up by Panasonic and after 3 weeks, I was told they are replacing the display unit and this should solve the problem!
    I was under the impression that you can not repair the plasma, a bit sceptical of Panasonic now
    Any one with similar occurrence or experience
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    there are lots of components within a plasma that can be replaced or repaired, PSU video chassis tuner components etc etc the plasma glass cant be repaired but can be replaced if you have only had it a week before this happened i would want a new one not a repair, or a refund, but having accepted the repair you may have gone too far down the road. It will be replaced or repaired tho and i assume you know the screens limitatations re HD material
  3. Kamin99
    Kamin99
    Sep 15, 2004
    346
    +10
    Thanks hornydragon for your comment, unfortunately my dealer claimed he can not replace the Viera without sending it to Panny for assessment, so after reading your reply I guess I should have been more firm with them
    Unfortunately also, I don't know the limitation reg HD , in fact I was driven by the specs ,saying it is HD ready
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    the TH-50PV30 is not HD ready it has no HDMI/DVI input and component input is not compatible with 720p it is the least HD ready 50" possible, see the trading standards sticky at the top of the general chat forum, get a refund and buy an HD ready plasma 50PV500 is "HD ready" as is Fujitsu P50XHA40US and the PIo 505XDE
  5. simon_evo
    simon_evo
    Panasonic do not come into the equation at all your sale of contract is with the supplying retailer. I would personally have demanded a brand new set or a full refund there and then which you are entitled to especially as the unit failed in only one week.
    I
  6. Kamin99
    Kamin99
    Sep 15, 2004
    346
    +10
    Thanks hornydragon and Simon
    must say I'm totally frustrated now i guess i did not research it well. I lread the reviews and thought it was HD ,i saw a AV-Sale site advertising HDMI terminal Boards for Panasonic plasma 50" would it work !http://www.av-sales.com/plasma/html/panasonic_plasma_terminal_boar.htm
    I will follow the advice and try a refund
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    That HDMI board is for the PANEL only plasma, do you have a TH-50PV30 or a TH-50PHW7? very very different beasts the PV30 has no card slots and PHW7 has 3!!!
    Also HDMI board is not HDMI 1.1 Compliant (cant accept 720p or 1080i @ 50Hz)
  8. Kamin99
    Kamin99
    Sep 15, 2004
    346
    +10
    I have the TH-50PV30, but I guess I can’t call it a beast after all this, thanks a million for your time and advice
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  10. Kamin99
    Kamin99
    Sep 15, 2004
    346
    +10
    My retailer is Harvey Norman, an Australian chain, in Dublin ,Ireland
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    ah never heard of them but irish law may be different to UK law so you will need to look into it at your end mate
  12. Kamin99
    Kamin99
    Sep 15, 2004
    346
    +10
    Thanks hornydragon for the eye opener advice, I approached my retailer again and just today i was told they will replace it with a new plasma,so i'm so pleased
    thanks again :clap:
  13. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    no worries mate perhaps take a bit more time choosing this one.................come back to the forum before going for it, get some feed back
