can the sub be placed on its side?
Discussion in 'Home Cinema Speakers' started by deman77, Sep 30, 2004.
  1. deman77
    deman77
    Aug 20, 2003
    263
    16
    London
    I have an AltecLansing 5021 2.1 speakers package to connect the iPod in the bedroom. Never heard sound that good from PC speakers :thumbsup: (120 quid for the lot) but the sub doesn't fit under the bed standind up. Is it an issue if I put it on its side? :confused:
  2. Ian J
    Ian J
    Aug 6, 2001
    25,630
    +4,906
    As long as you don't block any air vents it won't harm it so give it a try. It probably won't sound as good though.
  3. deman77
    deman77
    Aug 20, 2003
    263
    16
    London
    thanks Ian.
