Can the Relisys RLT1720 LCD TV be 'wall mounted'?
Discussion in 'Home Cinema Buying & Building' started by Jon Weaver, Oct 28, 2003.
  1. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,051
    Born in Bristol but now in Newport, (for my sins)
    +664
    I am looking at the RLT1720 and wonder if it can be 'wall mounted'.
    Looking at pics from at the back, doesn't show any way to do it, other than an oval handle at the top.
    Do Relisys make a 'wall mount' kit for it? If not, is there any way to do it?
  2. EffTee
    EffTee
    Jan 20, 2002
    196
    Bristol
    +5
    The description of it on the Dabs site certainly describes it as wall mountable. They also list a Vesa Uniball wall mount.
    EffTee
  3. MCB
    MCB
    Jan 28, 2003
    33
    Flackwell Heath, Bucks, UK
    Yes it is possible to wall mount. The oval handle is removable, revealing the VESA mount. Not sure where to get a Vesa mount, though if search for other threads on this display you should see someone mention it
  4. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,051
    +664
    Ah.. Just looked at the picture and can see that its 'hangs' quite a way off the wall.
    Is there any other kind of mount which will hold it 'flat' against the wall.
    Saying, that it looks like it only screws into the back of the panel with a number of screws (It looks like four in the picture). As I have a decent set of tools in my workshop (including a welder), I am confident I can fabricate something which will hold it close to the wall for next to nothing!
  5. MCB
    MCB
    Jan 28, 2003
    33
    Try www.nexnix.co.uk. They have a range of VESA compatible wall mounts, cost is around £50.
    Here is the link to their TFT accessory page:
    http://shop.nexnix.co.uk/NexNix_Online_Shop_TFT_Monitor_Accessories_17.html
