Can the Pioneer 575 play RCE Discs?
Discussion in 'Blu-ray & DVD Players & Recorders' started by sambobo, Apr 4, 2005.
  1. sambobo
    sambobo
    Dec 23, 2004
    131
    Hi, i have a multiregion pioneer 575 and was wondering if anyone knew if it can play RCE discs?
    thanks
  2. shodan
    shodan
    Dec 11, 2001
    10,303
    shoeburyness
    +4,681
    I've not found a disc that it won't play! I've even put about 40 albums on a DVD-R, which it catagorically states in the manual that it can't play MP3's on a DVD-R, and it plays it perfectly and even list's each album and song!
  3. sambobo
    sambobo
    Dec 23, 2004
    131
    thanks shodan, but im taking about R1 dvds that have had Region Code Enhancment added to them. has anyone got any R1 RCE discs, (check playusa.com for discs) and do they play on the pioneer 575 ok. i ask this as it dosnt have a way of setting the region it does it automatically which can mean it wont play RCE discs.
    thanks
  4. badgerboy
    badgerboy
    Apr 14, 2003
    37
    9
    Kingston Upon Hull
    I've had a 575 for quite a while now, and it's played everything I've thrown at it. I have a copy of Tora! Tora! Tora! on R1, and I seem to remember that it has RCE on it. No problems playing that. Play.com list only the new special ed. version, and it doesn't say now whether it's RCE or not.
  5. sambobo
    sambobo
    Dec 23, 2004
    131
    thanks badgerboy, yeah the new version seems to be rce free. does anyone else have any RCE discs theyve tried??
  6. Kryters74
    Kryters74
    Jul 23, 2004
    239
    London
    +7
  7. Barnetto
    Barnetto
    Jan 5, 2005
    69
    Sorry, somewhat different 575 query - but does this DVD player output from both the RGB scart and from Component cables at the same time?
  8. Benfica
    Benfica
    If you select RGB then it will not output component, although if you set SCART to output composite or Svideo it will output also component.
    HTH
  9. sambobo
    sambobo
    Dec 23, 2004
    131
    cheers guys, it probably does play rce discs then, i think most modern MR dvd players do, but its good to check.
    thanks
