Can the Panny DMR-ES10 be multi-regioned?
Discussion in 'Blu-ray & DVD Players & Recorders' started by JamieBee, Jul 27, 2005.
  1. JamieBee
    JamieBee
    Jun 28, 2005
    934
    Ashford, Kent
    +10
    And if so. How ? Anyone have a hack for it ?
    :lease:
  2. Caveman643
    Caveman643
    Jun 16, 2005
    516
    Darlington, UK
    +51
    Mine came ready multi-region from RGB Direct. So yes it can. How they did it I don't know. I've had a look on videohelp.com but there is nothing on there either.
  3. Goooner
    Goooner
    Jul 23, 2005
    35,522
    2
    Milton Keynes
    +13,948
    I think you need a special remote to do it, try www.dvdchips.co.uk they do them for about £20, I should be getting an ES10 tomorrow so I'll probably use them to hack it.
  4. Goooner
    Goooner
    Jul 23, 2005
    35,522
    2
    Milton Keynes
    +13,948
    Have now ordered said remote from dvdchips, total cost £23.50, despatched within 24 hours supposedly, so hopefully will receive it by the weekend. Will post an update then on my success or otherwise with it.
  5. ColdKilla
    ColdKilla
    Jun 21, 2005
    726
    +19
    Any news yet?
  6. Goooner
    Goooner
    Jul 23, 2005
    35,522
    2
    Milton Keynes
    +13,948
    When my ES10 arrived, much to my surprise it was multi-region out of the box (not advertised as such) so I didn't need the remote after all.
    So if anyone wants the remote cheap, feel free to make me an offer.
  7. ColdKilla
    ColdKilla
    Jun 21, 2005
    726
    +19
    Mine has just come but it aint multi region where was yours from?
    Assuming you aint used the remote as it onyl works once I will offer ya a fiver :thumbsup: :thumbsup: :thumbsup:
    CK
  8. Goooner
    Goooner
    Jul 23, 2005
    35,522
    2
    Milton Keynes
    +13,948
    It has never been used, make it a tenner and your on :)
  9. ColdKilla
    ColdKilla
    Jun 21, 2005
    726
    +19
    Delivered?
    CK
  10. rb5201
    rb5201
    Apr 20, 2005
    2,097
    63
    essex
    +212
    How can you tell if its multi region or not?
  11. ColdKilla
    ColdKilla
    Jun 21, 2005
    726
    +19
    Just stick in a region 1 disc!
    CK
  12. Goooner
    Goooner
    Jul 23, 2005
    35,522
    2
    Milton Keynes
    +13,948
    Yep, PM me if you want it.
