Can the new Hitachi5000 series take DVI signal?
Discussion in 'Plasma TVs' started by azz, Jun 21, 2004.
  1. azz
    azz
    Feb 22, 2003
    644
    28
    Nottingham
    +22
    I am about to buy the Hitachi 42PD5200 plasma. The only thing puttig me off is if the DVI takes a suitable feed from a dvd player.
    Currently i have a Tosh 330e
    Ive looked at the manual online and no help there
    Please help Azz
  2. John
    John
    Dec 13, 2002
    10,967
    +2,653
    The hitachi does have a dvi-d socket on it , but I think you will need a hdmi equipped player or hcpc to take advantage of it , Don't think the tosh has a suitable output (if it does I'm off down the shops :D )
    john
  3. dUnKle
    dUnKle
    Jan 1, 2001
    13,476
    +1,405
    Mine takes an input from the PC
    Would love a standalone DVD player that did it though
  4. azz
    azz
    Feb 22, 2003
    644
    28
    Nottingham
    +22
    Thanks for your replys
    The manual does say it takes PC and STB (?satelite) via DVI but no mention of a DVD player such as the samsung 935.
    I just want it to be future proof?
    Whats the pics like through component?, i have seen a RGB fed one in curries and did not look as detailed as a non pixel + phillips ?945
    Azz
  5. qaiser
    qaiser
    Jul 29, 2003
    36
    London
    I am using the Hitachi 42pd5000, feeding it with DVI from a Momitsu V880 dvd player. 720p and 1080i looks excellent. I prefer 72p, which gives a slightly sharper image.
    BTW, I also get a suprisingly good image from a Netgem Iplayer and Freeview through RGB SCART.
    Q
  6. Blu Ray
    Blu Ray
    Jun 14, 2004
    495
    Chorley, Lancs
    +12
    HDMI & DVI-D are compatible, you just need a HDMI-DVI cable or an adapter. HDMI DVD players are quite pricey though.
  7. The_Wierd
    The_Wierd
    May 2, 2002
    1,130
    Lancashire
    +316
    Quaiser, can I ask where you got the Momitsu player from, and how much?
  8. qaiser
    qaiser
    Jul 29, 2003
    36
    London
    The Weird,
    Yes , I actually have two. One I bought imported direct from Manowa in Taiwan. Cost me 160 pounds all in. The second is a 'Brainwave' labelled player, which is exactly the same as the Momitsu. I bought that for 120 pounds off the Forums. I think you can import reliably from hivizone www.hivizone.com in Hong Kong. Both players updated to latest firmware.
    Good scaling and mpeg2 decoder and convenient vs. an HTPC.
    Q
  9. NaTT
    NaTT
    May 27, 2003
    1,106
    +77
    Them momitsus make me think that twice about my HTPC project. You can impot one from HK for less than a high end graphics card.
    Now are there any units with Ethernet ports like the Kiss devices, that can play video files and pictures from across a network?
    If so they beat HTPC handsdown on features to pounds
  10. Dutch
    Dutch
    Dec 5, 2002
    2,580
    3
    North Yorkshire
    +263
    NaTT,
    You may want to wait for the upcoming Momitsu V880N which features a network connection. Check out www.manowa.com.tw for details - that's when the site is actually working! Hope this helps.
    Steve
  11. NaTT
    NaTT
    May 27, 2003
    1,106
    +77
    thanks Dutch, it sure does. But what is it about tiawaneese web sites? MSI's and Zalmans are just the same
  12. NaTT
    NaTT
    May 27, 2003
    1,106
    +77
    If it can out put at 1080p, how does that marry up to a screen with say 1024x768 resolution? It's not going to be pixcel to pixcel mapped is it? So is that where a HCPC running descaler can help?
  13. qaiser
    qaiser
    Jul 29, 2003
    36
    London
    Natt,
    I don't think the Momitsu will output 1080p, however you can configure it to output custom resolutions for your display device. I am experimenting with the best options for my Hitachi 42pd5000 plasma. Right now I am using 1024x512 @ 50Hz for PAL DVD. I use an app called cr4v880 to work out these settings. The app is available here:
    http://www.avsforum.com/avs-vb/showthread.php?threadid=330731&highlight=cr4v880
    This resolution is as close to native for the alis panel. I would say that you would probably get better (10-20%?) results from dscaler for de-interlace, but is it worth the extra hassle?
    Qaiser
  14. VT 4 CCTV
    VT 4 CCTV
    Does any one know where I could see a demo of the 5200 with DVI, or at least see some good images, coming from Sky / DVD's.
    Looks like there arent many AV shops in Kent that do ?????
    Had 1 demo of 5200, but must say, that i wasnt impressed. I think thats because the setup wasnt as good as i expected.
    Qaiser, can i ask, has the Momitsu DVI, really made a difference for you , and how long was the delivery time from ordering, as you bought this from Taiwan?????
  15. qaiser
    qaiser
    Jul 29, 2003
    36
    London
    VT4,
    I'll post some images. I don't use SKY only Freeview and DVD. I really bought the Momitsu because it has the ability to output analogue RGB through the DVI. This allows me to use a DVI to VGA converter plug and pass the RGB signal to a CRT projector. I can now send scaled images to the CRT projector and a 7 ft screen in a cinema room. I then bought the 42pd5000, which I thought was good value compared with Pioneer 434 and HD Panasonics. I get perfectly good pictures with the 42pd5000, I sit about 8ft away. Up close there are definitely interlacing artifacts with Freeview. I am not convinced by the Momitsu and DVI. The picture is sharp enough and artifact free, but the colours seem somehow muted compared with Freeview.
    The Momitsu took 3 weeks to arrive from Manowa. Hivizone, and these guys: http://www.taipeipc.com/ are apparently very fast at shipping.
    Qaiser
  16. Dutch
    Dutch
    Dec 5, 2002
    2,580
    3
    North Yorkshire
    +263
    qaiser,
    Have you updated your Momitsu's firmware to the latest issue? You would have better picture adjustment over DVI and it should cure your colour problem. Hope this helps.
    Steve
  17. dUnKle
    dUnKle
    Jan 1, 2001
    13,476
    +1,405
    What picture settings did you finally settle on - I still get the odd bit of smearing on Sky pictures
