Can the AX100 do 1080p24 over component
Discussion in 'Projectors, Screens & Video Processors' started by gamingdave, Sep 11, 2007.
  1. gamingdave
    gamingdave
    Jan 19, 2005
    213
    28
    +61
    As the title says, can the Panasonic AX100 do 1080p24 over component or is it limited to the HDMI port.
    Having recently moved, and upgrading my kit, Id like to just run one component cable to the back of the room (to carry Wii, 360, Virgin HD, and the PC - which will have HD DVD player, and maybe blu-ray), instead of a long HDMI run aswell (and then needing an HDMI swithcer and splitter or messing arround with cables). The run will be about 25 feet.
  2. dunamis
    dunamis
    Mar 8, 2005
    200
    +5
    How are you going to switch between all those different devices if you do run a single component cable?
    Ronnie
  3. gamingdave
    gamingdave
    Jan 19, 2005
    213
    28
    +61
    I was planning on picking up a component switch box. I could go with multiple cables (HDMI for PC and TV, component for Wii, and VGA for 360) but I dont really want to have lots of runs, and the HDMI ports on the PC and TV box will all be runnimg to a TV allready.
    If someone made a cheapish switch, that could upscale everything to HDMI, and output to 2 devices at once then thats what id get, but ive struggled to find such a thing. And whilst my amp may be old (Yamaha DSP-A2) it still has a lovely sound so im not looking to upgrade it yet, to one with more modern video switching.
    Anyway, the main question is can it handle 1080p24 over component.
  4. Bill
    Bill
    Oct 31, 2002
    568
    3
    Dungannon
    +49
    The AX100 is a 720p machine, not 1080p. it will however output 1080i
    Bill
  5. gamingdave
    gamingdave
    Jan 19, 2005
    213
    28
    +61
    Thanks Bill,
    you are correct in that the AX100 is a native 720p projcetor, howerver it can accept 1080p24, the importance being on the 24 fps for smooth panning.
  6. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    i am pretty sure you cant get 1080p over component for movies, you can only get 1080p for movies using hdmi or vga.
  7. gamingdave
    gamingdave
    Jan 19, 2005
    213
    28
    +61
    Having found the manual online (paper one temp lost due to house move) it seems I can now answer my own question.
    It CAN excpet 1080p24 over component, aswell as 1080p50 and 1080p60
  8. bevette
    bevette
    Jun 15, 2004
    88
    +8
  9. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    it might accept it but no player can send it over component due to restrictions, so the best you can get for movies using component is 1080i/50hz/60hz.
  10. gamingdave
    gamingdave
    Jan 19, 2005
    213
    28
    +61
    Is that a restriction of players? Would it work from a PC?
    If no player is capable of outputting the signal, why would the projcetor be capable of recieving it?
  11. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    not sure, i know with the 360 you can play games at 1080p over component but with the hddvd add on you are restricted to 1080i.
    I think the restriction is due to CSS (DVD) and AACS (HD DVD & Blu-ray) copyright provisions that dont allow anything movie related at 1080p over component.
  12. gamingdave
    gamingdave
    Jan 19, 2005
    213
    28
    +61
    Good to know chic.
    I gues I need to hunt on how well the copy protection has been circumvented on the PC then I guess.
