Turn you amp on and play some music. Now turn the volume down very slightly, just enough to notice a slight change in sound level. That slight change is the difference between 200w/ch Amp and a 100w/ch Amp.
The
Monitor Audio Silver 8 have 2x6" bass driver and a Sensitivity of 90db. That's good, but not great relative to Sensitivity.
The Amp -
Musical Fidelity M6si - is a pretty nice amp. Curious,
is the Volume Control set to the same position for all Sources - CD, Turntable, Other?
M6si | Integrated Amplifier The M6si is a new amplifier with incredible realism and emotional involvement....
www.musicalfidelity.com
The
Rega Apheta II is an MC Cartridge. Curious, do you have an external Phono Pre-Amp? Are you sure your M6si is set to MC?
Rega Apheta 2 Moving Coil Cartridge The Apheta 2 is the second generation of Rega's unique moving coil cartridges. Taking the technology developed from the first Apheta to the next level, Rega's engineers have fine tuned every aspect of the original design. Apheta 2 features a super...
upscaleaudio.com
A typical MM Cartridge will put out about 5mv. A typical MC will put out about 0.5mv. Your MC Cartridge is rated at 0.35mv, so it is not putting out excess signal. Many of the
High Output MC will put out about 2mv, which could cause extra Volume Control sensitivity, but that does not seem to be your case.
It is possible that you are simply seeing the calibration or general nature of the Musical Fidelity Amp's Volume Control. I'm wondering of other with experience with this Amp can confirm this.
To you core question, I don't think it is the Amp's power, as the difference in volume between 100w and 200w is small. I suspect it is more likely the general calibration of the Volume Control.
Or ... it could be something wrong with the Amp. The only way to determine that is if we can communicate with someone else who has/had the same amp, and see if they are using a similar Volume Control Setting.
Or perhaps a call to your dealer or Musical Fidelity, to see if the Volume Control Sensitivity is common for Musical Fidelity amps.
THOUGH - I wonder if all sources sound the same, that is use the same volume position? If it is just one of the Inputs or one source, then we may have other problems.
Just a few thoughts.
Steve/bluewizard
