can someone tell me if this looks right pls
teljess
ok this is my first build and i need to know if the connections look right/ok.There is no hd/dvd drive fitted at the mo(cheers ebuyer) but the other stuff in.
i want to boot it up just to check the fans and the gpu are working (oh and i am excited sad git that i am)
so could i have your opinions pls
shadowboxer
Established Member
From those pictures shown it all looks OK.
Things to double check would be the front panel connectors - very easy to get them mixed up and I can't make them out from here. Just go over them with the motherboard manual open.
What graphics card is that? Make sure the PSU is upto the task.
Make sure RAM and securely seated.
Then just test it...
teljess
the graphics card is a hd6950
the psu is xfx 750w
the ram is locked in properly
i am worried about wheteher or not the front end connectors are right,followed the manual but it was not very clear.would it cause any damage if they are wrong or would it be a case of swapping them round
shadowboxer
Established Member
Yeah, the front panel connectors can be quite tricky and fiddly.
As all their doing is controlling switches/lights on the case you won't do any damage if you've got them the wrong way around.
What you can do though is only use power (+) and power ground, no need for HDD activity as you don't have a drive in there and also leave out the reset ones. Just get the pos and negative the write way around.
Also nice choice of components. If that is a rev. 1 6950 you will be able to unlock the shaders and flash it to a 6970!! Nice PSU too, will take another 6950(70) if you Crossfire them later on.
teljess
thats what i plan to do later on add another card(the missus will kill me if i tell her i am getting another 1) just booted it up and it all works :clap:
shadowboxer
Established Member
Nice one, get installing some game and enjoy!
Dont worry, he got support in component choice :)
And yes mate everything looks good.
edit - didnt read your last post fully :p
Rocky 4K, Creed 3 and boxing movies, Shazam 2, 65 trumping Jurassic World Dominion, + Picard & Mando
