Answered Can someone tell me if this is an ok build for a gaming pc?
Discussion in 'PC Gaming & Rigs' started by haydenevans1, Jun 22, 2015.
  1. haydenevans1
    haydenevans1
    Jun 22, 2015
    4
    Parts Unknown
    My specs for my pc are;
    AMD Athlon A8-6600K
    Processor Cores 4
    Processor Speed 3.9GHz (4.2GHz Turbo)
    16gb ddr3 ram
    AMD Radeon HD 8570D graphics card (2gb vram)
    Hard Drive 1TB SATA3 6Gbps
    Optical Drive 24x DVD/CD Rewriter
    Wired LAN 10/100/1000 Mbps LAN
    Wireless LAN (WiFi) 300Mbps Super-fast Wifi
    Video Outputs VGA (D-Sub), DVI-D, HDMI
    Memory 16GB
    Power Supply 500W
    Case CiT 1017 Black Part-Mesh Gaming Case
    Motherboard Gigabyte F2A68HM-HD2
    - HD Audio
    - 1x PCI Express x16, 1x PCI Express x1, 1x PCI
    - 2x back USB 2.0 ports
    - 2x back USB 3.0 ports
  2. Best Answer:
    Post #2 by andiuk007, Jun 22, 2015 (1 points)
  3. andiuk007
    andiuk007
    Mar 28, 2012
    6,664
    Oldham
    +4,868
    Best Answer
    I don't want to burst your bubble but that isn't really a gaming PC, it will struggle with older PC games and will have no chance with modern games.
  4. GMC79
    GMC79
    Apr 1, 2006
    10,667
    Glasgow
    +3,187
    Yeah, unless ur happy with 720p lowest settings barely 30fps.
    Far Cry 4 Gameplay On AMD A8-6600K APU with HD...
  5. Smurfin
    Smurfin
    Aug 13, 2002
    21,466
    +4,399
    So basically like playing the game on an X-Box 360...
    Also, if your PC is only for gaming, generally you don't need 16GB RAM (8GB). Especially if you're on tight budget the money will be better spent elsewhere.
  6. aslird
    aslird
    Sep 8, 2011
    6,106
    +4,291
    Looks like an ebay "special" to me. i.e. not very good at all.
  7. jamiehard1989
    jamiehard1989
    May 30, 2014
    1,340
    Herts
    +189
    should of got the a10 7850k for a apu, so you could play at 1080p,
    it sure does look like a ebay cheap pc with a psu which more than likely blow up at some point
  8. andiuk007
    andiuk007
    Mar 28, 2012
    6,664
    Oldham
    +4,868
    Apart from the bad graphics and terrible fps the tearing is absolutely shocking in that video, it would drive me crazy!
  9. nero0410
    nero0410
    Jan 5, 2004
    12,702
    Weston Super Mare, UK
    +5,051
    Don't let that put you off though, save more and get better and it'll be well worth it in the end :)
    tris
  10. GMC79
    GMC79
    Apr 1, 2006
    10,667
    Glasgow
    +3,187
    yeah tearing
    would be bad at them low fps. tearing dont bother me tho tbh vsync off all day lol. If it's there on the odd game it's never too bad and ive learned not to care about/or not notice it.
  11. Smurfin
    Smurfin
    Aug 13, 2002
    21,466
    +4,399
    I wish tearing didn't bother me, but I can't stand it now. I find it to be a complete immersion breaker, and it just reminds me that I'm playing a video game! (well you always know of course, but it breaks you out of the moment).
  12. GMC79
    GMC79
    Apr 1, 2006
    10,667
    Glasgow
    +3,187
    If it's bad like in that video then yeah i agree and looks worse with the low fps, but generally u dont get much if any if around or above 60fps.
    OP gonna need dedicated GPU or may as well just go to the consoles.
  13. Theydon Bois
    Theydon Bois
    Jun 26, 2007
    16,212
    Sauf Lunden
    +7,236
    .....a new user, given the stark cold truth. Great! He wont be back :)
    Hopefully untrue, and sadly can only echo what has been said above. Check the stickys in this forum for some build options and stay away from any ebay builds in general (I am sure there are some good ones, but most are not). As a very rough build, stick with an Intel i5 CPU as a minimum for a gaming machine build, with a GPU that is a minimum of £150.
    If you have a budget, then post here and more than one of the members here will help you spend it, then spend more on top. :)
  14. andiuk007
    andiuk007
    Mar 28, 2012
    6,664
    Oldham
    +4,868
    I think the going rate these days is add roughly 25% to the budget, if the buyer is weak maybe double that :)
  15. Smurfin
    Smurfin
    Aug 13, 2002
    21,466
    +4,399
    I think that covers almost everyone who's ever had help on here with a build :laugh:
  16. andiuk007
    andiuk007
    Mar 28, 2012
    6,664
    Oldham
    +4,868
    So that answers it, budget +50% :thumbsup:
  17. Smurfin
    Smurfin
    Aug 13, 2002
    21,466
    +4,399
    I think I went +100% thanks to you lot :eek:
    To the OP: there's plenty of people here who can give you solid build advice, you just need to outline your budget and if it's quite tight, the classifieds are often a good source of cheap but still decent components.
    I'm making a big assumption that you're willing to build a machine, because that's probably the best way to go. If you've not thought about it before, then don't be put off, they really aren't difficult to build and it's a bit like pulling together a jigsaw puzzle with just a few pieces. It's fun too :thumbsup:
