Can someone recommend a Subwoofer cable for me?
Gavin C1
I'm looking for a good quality subwoofer cable.
Length is about 10m
Looking for something with good shielding and gold connectors etc
Stumbled across this Fisual cablel but not sure about it. Has anyone used these cables before. And that website, is it recommended?
Any help would be appreciated :thumbsup:
Thanks for reading
Gav
EDIT: Looking to pay about £10, although will stretch a bit.
P-P-S-S
Gav, it's a very subjective topic really. It depends what you would call good quality. From what i have heard it is reccomended that the cable is 75ohm and properly screened. For 10m and £10 budget i dont think you will be able to get a decent one really. In my opinion you would need at least £30.
davepuma
Profigold make good quality cables on a budget and I'm pretty sure their 10m sub cable is less than £20. Ixos do a budget blue range as well, which I have used in my car and they're good quality too. They probably make a sub cable as part of the range.
