Can someone please explain how it is possible for a digital CABLE to induce jitter?
Discussion in 'Cables & Switches' started by NicolasB, May 24, 2003.
  1. NicolasB
    NicolasB
    Oct 3, 2002
    6,512
    Emily's Shop
    +916
    This is a point which which has always troubled me.
    It's fairly well established, now, that even a rather poor digital interconnect won't be poor enough to introduce any actual bit errors. (There was the famous case of someone getting no bit errors at all while using a wire coat hanger as a digital interconnect).
    I think we've also managed to establish that, for movie soundtracks (DD, DTS, etc.) jitter is completely irrelevant if it's higher up the chain than the processor, because the data is compressed and therefore must, by definition, be buffered and reclocked before it hits the processor's DACs. (So jitter in the player or interconnect can't have any influence on the eventual sound).
    But jitter certainly can have a big impact on the performance of a processor playing back a PCM stream, e.g. when a DVD player is acting as a CD transport and the processor's DACs are doing the conversion. This fact is often quoted as the reason why a more expensive digital interconnect can have an influence on sound quality.
    But I have yet to come across any explanation as to how a cable can introduce jitter. How is it possible for one pulse to pass through it at a different speed from the next one?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    This has troubled me too. How ever as an undergrad electronics engineer it seems to be a mix of potential problems.
    PCM (Pulse code modulation) on a cable can result it the cable impeadance changing with signal and the use of less than perfect 75ohm terminations can cause signal reflection at the interface. this i beleive is where the jitter comes from the interferance of the reflected signal on the following signal. I think it is all buried deep in the modulation. as un modulated signal are very much easier to transmikt but also more expensive. I have no idea if PCM has any real advantage for Music replay or whether it was just the "best" system available at the development of the media. Hope this helps nicholas.
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,441
    Somewhere in South Yorkshire
    +5,852
    I suspect that the cause of this phenomenon in the same as the phenomenon of Plasma TVs losing 'gas' and needing to be recharged.
    Fiction.
  4. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    That isn't my experience. In my view DVD players vary quite a lot in their DD/DTS passthrough performance, the same with sound cards in PCs. In fact with PCs even the software decoder makes a difference even though the sound is supposed to be untouched. I think jitter is still very relevant with DD and DTS.
  5. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    Slartibartfast has posted information about this on another forum that you frequent Nicholas. You could also read TAG McLarens white paper on how they designed their digital interface and cables for DVD32r and AV32r.
    Gordon
  6. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    I have already posted the link but some has seen fit to remove it :(
  7. NicolasB
    NicolasB
    Oct 3, 2002
    6,512
    Emily's Shop
    +916
    A lot of PC soundcards mess things up by trying to convert sampling frequencies on the fly (ugh) so I'm not sure how comparable that is....
  8. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    How do you resample DTS without killing it?
  9. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
  10. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    I did realise a link needed moderating :(
