Can someone help me with setup of Rel Q150e and Pioneer VSX2014i please?
Discussion in 'Subwoofers' started by TarPot, Jun 15, 2005.
  1. TarPot
    TarPot
    Dec 16, 2002
    2,698
    103
    +271
    Hi all.
    I'm a subwoofer noob and would very much appreciate your kind help.
    My set-up I guess is a bit of a mish mash, but I like the sound it makes.
    I have a Pioneer VSX2014i amp, fronts-Mission 733s, rears-Mission 773s and centre-Kef 100 reference series.
    I've just got a good deal on a Rel Q150e and greatly need some advice on set-up.
    Rel recommend using both the neutrik cable and the phono cable, where Pionner say just use phono. From reading other posts I understand (I think) that Rel's method is better. So as not to lose bass in direct mode.
    The amp does auto MCACC set-up. What do I need to set my sub levels at? Because I guess if you have the sub turned up, the amp will compensate on auto set-up and turn it's levels down?
    Could any one give me a rough idea as a starting poing where to set my levels-Low, Hi, Rolloff, Mode?
    The default crossover on the amp is set to 80hz would that be ok for my system?
    I know that this kind of thing is down to the individual's taste, but if anyone could offer me any help as a starting point I would be very grateful.
    Thanks-a-lot
