Can Someone Help Me Out
Discussion in 'Desktop & Laptop Computers Forum' started by PAULRYAN52, Mar 13, 2006.
  1. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    552
    Liverpool
    +8
    Hi i was wondering if anybody can help me get my printer working over my network, here is my setup.
    Router is Netgear WGR614v4
    Printer is Epson R200
    Pc is connected to router via Ethernet
    Printer is connected to pc via USB
    Laptop connects to router wireless
    Help would be much thanked
  2. intersting
    intersting
    Open up control panel,
    printers and faxes (printers and other hardware in xp),
    add printer
    in the pop up box, press next, then select "a network printer, or a printer attatched to another computer"
    browse for a printer
    in the drop down list that will appear (allow it to laod first) you should see the pc and the printer you wish to connect too.
    hope that helps.
  3. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    552
    Liverpool
    +8
    on the laptop or the pc
  4. intersting
    intersting
    sorry, think i may have got slightly ahead of myself
    is your printer connecetd to your pc working?
    can your pc and laptop talk to each other e.g. share files?
    you will need to run the above add printer process on your laptop.
    you may need to set up a local network between the two machines, very easy to do, happy to talk you through it.
  5. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    552
    Liverpool
    +8
    the printer is working for the pc but like it working for the laptop.
    i dont think they talk to each other
  6. intersting
    intersting
    did you try running my first reply on your laptop?
  7. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    552
    Liverpool
    +8
    i will try what you said later someones using it at the moment
  8. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    552
    Liverpool
    +8
    i tried it but it didnt work
  9. intersting
    intersting
    sorry, only just got back to a computer
    it sounds to me like what you need to do is setup a network. go into control panel again,
    control panel
    network setup wizard.
    in here create an identity for your computer e.g. paul's pc (if setting it up on the pc) and a network, or "workgroup" name e.g. paul's network.
    select "enable file and printer sharing".
    now, go to your laptop, follow the same instructions as above changing your computer name to e.g. paul's laptop.
    now, go through the first set of instructions i gave you, and you should be onto a winner.
  10. intersting
    intersting
    any luck?
  11. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    552
    Liverpool
    +8
    i tried it but it still wont find the printer i can see the other computer but not find the printer
  12. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
    On the PC with the printer attached open "Printers and Faxes" from the start menu. right click on your printer and choose "Sharing" from the menu.
    Select the "Share this printer option" putting whatever name you want in the box below. Click OK.
    now on the laptop open "Printers and Faxes" from the start menu. choose add printer from printer tasks on the left panel, click next then choose the second option "A network printer or printer attached to another computer"
    Now browse to your Desktop PC and you should be able to select the printer
  13. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    552
    Liverpool
    +8
    i done what you said but the printer does not appear after my name
  14. Uridium
    Uridium
    Jan 29, 2005
    14,434
    +1,855
    When adding the network printer on your laptop did you try Double clicking on the name of your desktop PC?
  15. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    552
    Liverpool
    +8
    yes but it still didnt appear
  16. intersting
    intersting
    is your printer turned on?
  17. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    552
    Liverpool
    +8
    yes
  18. intersting
    intersting
    ok, and just to check, its connected to your desktop pc and you can print fron your desktop pc to the printer?
    are you running windows xp?
    not trying to take the mick, just to get things clarified
  19. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    552
    Liverpool
    +8
    its connected and is printing from pc. pc and laptop both run xp pro
  20. andrew1810
    andrew1810
    Apr 4, 2004
    1,180
    North East
    +55
    If you know the computer name of the desktop (right click on my computer and click properties if you don't), on the laptop press:
    Start (enter)
    Run (enter)
    \\computername
    Then press enter
    If the printer appears in the printers and faxes folder in here, right click on it and click connect.
  21. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    552
    Liverpool
    +8
    Thank You so much for all your help. as you can guess it worked.
