Can someone explain exactly what is a Quad LNB?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by nicolala, Sep 17, 2007.
  1. nicolala
    nicolala
    Apr 23, 2006
    4
    I have got Sky set up outside the UK.
    I have a Sky+ box and I am paying Sky for Sky+ but I do not have full Sky+ functionality - I can only record the channel I am watching.
    From the web searches I have done so far, I gather this is because I don't have the right receiver on my dish. I think I need to get something called a Quad LNB. Does this sound right? Could someone explain to me in layman's terms what this is? Will it be an easy job for a satellite engineer here to get hold of one and install it? Obviously I cannot speak to Sky because I am outside the UK.
    Thanks.
  2. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    the part on your sky dish where the cable plugs in is the lnb, if there is only one cable fitted then you probably have a single lnb, if there are two cables then it is likely you have a quad lnb, the single or quad just refers to the number of cables that can be fitted to the dish, for sky + to function correctly it needs two cables, one for what you are viewing and one for what you are recording,
    check on the back of your sky box that you have cables connected to input 1 and input 2, they are clearly marked and the cables screw on, dont confuse then with the RF outlets which are completely different.
    Just make sure these are securely fitted,
    for further info report back here for further guidance..
    ps, it is not unusual for these cables to come out of the screw in connector, so give a GENTLE tug to make sure they are a firm fit
  3. nicolala
    nicolala
    Apr 23, 2006
    4
    Thank you - that is very clear. I can see that I only have the one cable going into input 1, so I just need to run another cable through from the dish. Great!
  4. fernandez
    fernandez
    Jun 5, 2005
    6,039
    +995
  5. tonkie
    tonkie
    May 16, 2005
    3,686
    Guernsey
    +897
    You should not be paying for Sky+, as it is now free with any Sky subscription
  6. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,600
    Oxford
    +1,335
    Unless it's on a Freesat card.:cool:
  7. tonkie
    tonkie
    May 16, 2005
    3,686
    Guernsey
    +897
    Nicolala has said he/she is outside the UK and has Sky set up so I presumed he/she has Sky and not Freesat:confused:
