Hi M8e,
Vipen said:
so is component the ultimate connection and if i run it through my amp will there be any image degradation?
I think that DVI/HDMI is the ultimate connection but very few amp do switching of them, so Component is the best of the switched ones. I don't notice any degridation, but haven't really compared it to anything else. If SWMBO likes the pictures then it must be ok
also, you have your dvd running through your sky box, how do you switch or do you just turn on dvd and it takes that signal over sky?
Yep, DVD player overrides skybox when DVD is turned on.
what if my ntl box (sky substiture right now) has no means of passing a signal through it?
It there are two SCART connectors on the ntlbox - it more than likely will support passthru - although not gauranteed. You may need a scart switcher otherwise, although there are other means of connecting it, not fully sure of standard connectors on Panny due to having a Pioneer panel
and lastly, i don't have a chipped xbox nor really thinking about it as if i turn it on drunk or a mate does it'll boot me off xbox live. forever!! so it's scart or nothing.
You don't actually need to have you xbox chipped to use the Hi-def kit, my Xbox isn't chipped but I still use the component connection from a third party hi-def kit, this gives me digital audio output also
so i'm stuck with too many connections into just one component slot on say the panny.
does the js device only take one scart to convert to component?
any ideas?
Pretty similar problem i'll have if I go for a new DVD player with component out - 3 devices on 2 component inputs on AMP.
The JS tech does only have one scart, hence my use of the passthru on the Sky box.
The are a number of solutions but I wouldn't like to say which is best, prices vary also upto a few hundred pounds - maybe worth putting a shout out to MAW or Hornydragon etc for details on that, maybe try a search of the forums to.
Either the DVD or the Xbox could be connected directly to the VGA input on the Panny, but that would mean you don't have source switching for it and you need to switch inputs on the Plasma also.
The other solution would be if your amp upconverts the other video inputs to component, like some of the Denons do, then feed NTL box via s-video into s-video input on amp, amp then upconverts to component and feeds signal out thru component out on amp to plasma (phew!) - not sure what affect this has on picture quality though.
checkout this posting - similar question/situation with some solutions :-
http://www.avforums.com/forums/showthread.php?t=183472
regards
Gary
