Can somebody recomend an online APS scanner serivce
Discussion in 'Photography Forums' started by azzo, Dec 22, 2004.
  1. azzo
    azzo
    Feb 13, 2002
    999
    Wokingham
    +9
    I have around 20 APS developed films that I would like converted to CD. I have found one company that will do a 24 film for 10 pounds. This is just too expensive.
    Has anybody else done this.
    The cheapest APS scanners are around 250 and I guess they would be a hastle to do.
    Any help would be appreciated
    Azzo
  2. PAH
    PAH
    Jan 29, 2002
    1,129
    48
    +63
    A work friend of mine just went through this investigation now he's moving over to digital and wants to scan in all his existing APS stuff.
    Seems all the services are charging a similar amount to what you've found. Not sure how many different services 'all' covers (maybe just one!).
    In the end he gave up and has ordered a Canon film scanner with APS capability. He intends to sell it on after he's finished with it, so keep your eyes on ebay if you want a bargain ;)
  3. azzo
    azzo
    Feb 13, 2002
    999
    Wokingham
    +9
    Thanks, not a bad idea, buy and sell on flee bay
    Azzo
  4. PAH
    PAH
    Jan 29, 2002
    1,129
    48
    +63
    I think the film scanning services charge so much because it can be a very slow process (as long as 10mins/frame if scanning at the highest resolutions). Not sure how accurate this is as it's just something I've picked up from the web, I haven't tried to do it myself. Maybe someone else can verify this.
    So, if you're thinking of getting a scanner, it might be worthwhile getting one that can batch scan. For example, Jessops do a Primefilm 3650 Pro, which can batch scan up to 40 frames if they are on a continuous roll, which I guess APS is if the film is taken out. It does cost around £270, but you might be able to get one cheaper in the january sales, or on ebay, or find something similar elsewhere.
  5. azzo
    azzo
    Feb 13, 2002
    999
    Wokingham
    +9
    Good point, If it takes a long time, then I simply don't have the time.
    I'm just trying to consolidate all of my prints into one nice medium.
    I will try the high street stores (boots/jessops) to see what services they have to offer.
    Many thanks
    azzo
  6. stuzyk
    stuzyk
    I would use my APS scanning company www.*******.uk
    Stuart
