Can Sky+ Record via its scart input
Discussion in 'Sky Digital TV Forum' started by Jarvo, Jul 20, 2004.
  1. Jarvo
    Jarvo
    Nov 30, 2001
    16
    Can anyone let me know if it is possible to use a Sky+ to record via it's scart rather than using the internal tuners.
    This may seem an odd question, but it would be very usefull for my security camera if I could set it to record while I'm out
    Thanks Lads n Lasses :thumbsup:
  2. Pyara
    Pyara
    That's an extremely good point and I hope that Sky serioulsy think about implementing such a feature (is possible) in their software updates, it would have a substantial sales value as it would allow consumers to record for CCTV or additional items if needed.
    However, the 2nd scart on the box is also an output designed for videos and although it has a pass-through feature, as far as I understand non of the signals from this connection are actually processed by the unit itself.
    I have CCTV installed at my residents and would welcome the idea of being able to record the images on the Sky+ simply because it would be so simply to delete etc. I can imagine having a special page (just like the current manual record page) where you can indiciate the frequency of the recording, either continous or say, and image every 5 seconds etc?
  3. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    SKY+ does not have the hardware (mpeg encoders) to accept input from an external source. It would need a totally new design to accomplish that and since SKY does not like to spend R&D money on anything that could be used for something other than SKY I doubt it will ever happen.
    There are many DVD/HD recorders on the market that can do the job for you, some with extensive editing systems on board and they are getting cheaper all the time.
