can projector do prog scan with non prodg dvd player?
Discussion in 'Projectors, Screens & Video Processors' started by dood, May 15, 2003.
  1. dood
    dood
    Aug 4, 2000
    943
    28
    Hobart
    +38
    Please forgive my ignorance. There's someone installing a home theatre at the moment. They are going for a Yamaha projector (probably the DPX100 DLP ). they have been told that a cheap non prog scan dvd player (Yamaha 530) will be fine as the projector will do the progressive scan stuff. Is this info correct? I was under the impression that you have to have a progressive scan DVD player. The supplier only does Yamaha stuff and says that there is no point getting the Yamaha prog scan dvd player as this is a PAL player (originally region 2 but multiregion modded).
  2. radiostar
    radiostar
    Yes, that is true. I don't know the Yamaha model in question, but if it has progressive scan built in you are fine just using a standard non-prog DVD player. I've heard that in some cases having both units (the projector and DVD) with built-in progressive scan can be to the detriment of the picture as they can produce conflicts.
    Nick
  3. Kramer
    Kramer
    All depends on the quality of the deinterlacer/scaler built into the PJ.
    Some have Farajouda deinterlacers & do an excellent job of deinterlacing - others aren't so good & so really require a prog. scan player for better IQ.
    Don't know the specs of that PJ - try avs for more info.
  4. Messiah
    Messiah
    Apr 22, 2002
    7,530
    +339
    If it is the same deinterlacer as the Epson TW100 (considering the LPX500 is a clone of that model with some enhancement tweaks and a redesigned case) then you will be hard pressed to find an external unit that will do a better job with spending BIG monies.
    I tried a Quadscan Pro, Briteview, iScan Pro, iScan Ultra and CS-1 with the TW100 and none of them did as good a job as the internal Faroudja DCDi deinterlacer. I can only presume that is becuase the built in one is optimised for that unit.
    IMO, unless you are prepared to spend meag bucks I wouldn't even bother.
  5. manny
    manny
    Jan 11, 2003
    182
    ireland
    i was wondering could any of you answer the same question about the panasonic projectors, AE100 and AE300?
  6. Kramer
    Kramer
    They certainly don't have a Farajouda deinterlacer - that's for sure. Accordingly they'll never equal the TW100 (& clones - Messiah ;) ), which is without doubt, the best at deinterlacing (on board).
    The AE100 really benefitted from 1:1 mapping via VGA so it's scaler isn't great either. Can't comment on the AE300.
    :smoke:
  7. Gordon @ Convergent AV
    Jul 13, 2000
    13,999
    +2,803
    ALL fixed pixel projectors work progressively. They ALL are therefore are doing progressive scanning. None require a progressive scan source to do progressive scanning.
    As has been stated above the difference is only in where it is done and how good the device doing the de-interlacing is. There is more to video processing than de-interlacing though so there may be reasons why external videoprocessing, in DVD or in a seperate box, may be better than that inside a projector. The best way to check is to do the dem.
    Hope this helps a little.
    Gordon
