Can Prog Scan recorders output without recording.
Discussion in 'Blu-ray & DVD Players & Recorders' started by mcaw, Sep 25, 2003.
  1. mcaw
    mcaw
    Sep 1, 2003
    92
    Do the Prog Scan recorders ouput the normal TV tuner in Prog Scan without Recording to DVD.
    Similarly do they convert any connected device to Prog Scan without having to record and playback.
  2. sub
    sub
    Yes, I'd also like to know the answer to this...
  3. mcaw
    mcaw
    Sep 1, 2003
    92
    Anybody ?
    Can they output any connected device in Prog Scan without recording?
  4. geordie
    geordie
    Oct 4, 2002
    80
    11
    Enfield, Middlesex
    +3
    I doubt it, but do not know. There is a separate forum for progressive scan, four up from the bottom of the list, I suggest you re-post your question there.
  5. sub
    sub
    I posted a similar question on another forum a few days ago. One member did reply to say that their Philips DVDR80 did indeed ouput live TV (being watched through their recorder) as progressive scan.
    This is good news for me. I was previously thinking about getting iScan Ultra deinterlacer $$$. Now, I'll probably go with a Philips DVD recorder instead. These recorders contain the highly regarded Faroudja deinterlacing chipset.
  6. azzo
    azzo
    Feb 13, 2002
    999
    Wokingham
    +9
    Sorry for bumping such an old thread, but does anybody know if this is a general feature across the popular DVD recorders. i.e. Can you use them as a deinterlacer.
    Many thanks
    Azzo
  7. sgruniss
    sgruniss
    Feb 18, 2005
    90
    +3
    I have the panasonic DMR E85 and ANY signal input is also outputted from component.
  8. azzo
    azzo
    Feb 13, 2002
    999
    Wokingham
    +9
    sgruniss that's great news. One more question, can you output RGB and component at the same time. (I'm guessing not)
    Azzo
  9. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    Providing the output is active you will usually get the signal type specified. So if a machine has Component RCA sockets, RGB/s-video/composite scart, s-video mini-din, and a composite RCA socket then you will get all signal types simultaneously. There is, after all, nothing to turn them of, usually only to specify what comes out of the scart. The audio sockets (RCA and digital if present) will be active all the time.
    So there should be no reason why Progressive Scan should affect this arrangement
    Also, scarts set to RGB usually send composite at the same time.
  10. TobyW
    TobyW
    Jan 6, 2005
    157
    Australia
    +3
    I've just bought a Sony plasma screen. Its instruction book says the VCR must be fed through a time base corrector. Also, I find it works better with progressive input, rather than interlaced.
    The Panny E85 performs both of those functions admirably. Also, as an experiment, I connected a digital tuner directly to the plasma as S-video, and also through the E85 as composite video (converting to progressive component video). The E85 route was the better!
  11. mrcoddy
    mrcoddy
    Aug 31, 2004
    12
    I like to add, I'd brought a Lite-On DVD Recorder a few weeks ago to use with my LCD TV via component just to watch the TV on, as the scarts on the LCD TV were crap.
    At first everything were ok, but as I tried to watch a flim on ITV2 or some other programmes, but the colours on people's faces kept changing to green and red. I believe this is something to do witht MacroVision in the signal.
    I was well p***ed off with it in the end and took it back to get a refund.
    So anybody whos looking to get this DVD recorder should stay well away from it.
    Carl.
  12. sgruniss
    sgruniss
    Feb 18, 2005
    90
    +3
    I watch everything through my panasonic , Rgb , s-video , composite . either rgb to tv or component to the projecter .
