Can picture settings be locked?
Ubarrow
I’ve just bought a 65” Oled C9PLA and spent some time adjusting the picture settings.
Just wondering if there is any way of barring access to the picture settings menu?
Can‘t find that feature anywhere, but is it there somewhere?
Inferno
You can lock the ISF ones if you want to, but not the others.
Also the above could work, but iirc it will give limited access to some settings but it will revert back once turned off and back on.
Ubarrow
Locking the ISF mode would be good. How do I do that? I’ve searched through all the menus and can’t find that facility.
Vid
Have done that, and it looks as if it might be the answer. But can’t work out how to do it. Has anyone here done it on this model?
Not at home to test but you could try holding down the settings button for 5 seconds or more then input 1105 then press OK.
Inferno
It's not an option in settings, I will message you the instructions.
Similar threads
